Your result of our little server check
Re: Your result of our little server check
Debian Jessie introduced Apache 2.4.10 as Webserver. Prior versions of Debian use Apache 2.2.x
Could you look in the "apache2.conf" in /etc/apache2/apache2.conf if you find this:
AllowOverride None
It must be allowed to override the "RewriteRule"
AllowOverride None
in apache2.conf you can find AllowOverride None. Standard apache2.conf looks like
AllowOverride Rewrite Rule is not working, i was not able to start apache again after changing to this value:
Apache restart was successful, but then: Error 500
I had to enable Rewrite
Now all four checks are ok.
I checked api test on another 1und1 webserver: Error 500, so rewrite should not be allowed there.
# Sets the default security model of the Apache2 HTTPD server. It does
# not allow access to the root filesystem outside of /usr/share and /var/www.
# The former is used by web applications packaged in Debian,
# the latter may be used for local directories served by the web server. If
# your system is serving content from a sub-directory in /srv you must allow
# access here, or in any related virtual host.
<Directory />
Options FollowSymLinks
AllowOverride None
Require all denied
</Directory>
<Directory /usr/share>
AllowOverride None
Require all granted
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks
AllowOverride None
Require all granted
</Directory>
#<Directory /srv/>
# Options Indexes FollowSymLinks
# AllowOverride None
# Require all granted
#</Directory>
There is an option AllowOverride All, also i changed the entry for directory /var/www to:H00526: Syntax error on line 166 of /etc/apache2/apache2.conf:
Illegal override option RewriteRule
AllowOverride All
Require all granted
</Directory>I had to enable Rewrite
sudo a2enmod rewriteI checked api test on another 1und1 webserver: Error 500, so rewrite should not be allowed there.
https://httpd.apache.org/docs/2.4/mod/c ... owoverride
maybe this is correct: "AllowOverride RewriteCond RewriteRule"
You have to set it in the right Directory section
Thomas-RCV said 1und1 works fine. mybe we have to look a little bit deeper
Edit: ok wait this is wrong. Hmmm... This is strange why RewriteRule is not allowed...
maybe this helps: https://httpd.apache.org/docs/2.4/mod/m ... ewriterule
Edit 2:
Edit 2:
To enable the rewrite engine in this context, you need to set "RewriteEngine On" and "Options FollowSymLinks" must be enabled. If your administrator has disabled override of FollowSymLinks for a user's directory, then you cannot use the rewrite engine. This restriction is required for security reasons.
We have two sites hosted by http://www.justhost.com/ and all scenarios in the script come back with an OK.
- Thomas-RCV
- Former team member
Edited my test result for 1und1.
Please have a look above. The same issue like Offe has
For "1und1.de" users:
Please try to add this on the beginning of the .htaccess file
https://hilfe-center.1und1.de/hosting/1 ... 92317.html
RewriteEngine on
RewriteBase /
I found same article, but for me there was no solution.
Ok then please try:
RewriteEngine On
RewriteBase /
RewriteRule ^ /index.php [QSA,L]
With new configuration i have 404 for test 2a --> nothing works
Please change the "RewriteBase":
Works for Thomas-RCV
# .htaccess File: "/absolute/path/to/your/.htaccess/.htaccess"
RewriteBase /absolute/path/to/your/.htaccess/
With RewriteBase and absolute path, no solution
There seems to be something wrong, because if i do not use .htaccess file, i can test 2 a with url/api . With .htaccess file i have to use url/api/index.php
- Thomas-RCV
Hi Offe,
I had the same problems after changing several times the htaccess.
I also had to call an index.php in the root.
But it seems to me that the Server possibly was a Little bit "confused" on my active system.
With the current Version from Ximex it works now.
Maybe you can me send your link ... for testing
-Thomas
-Thomas
@Thomas-RCV
It works without call the "api/index.php" itself it works with "api/" too
My webspace is hosted by http://goneo.de and all test results are ok.
