Get a report of how many years someone is in a role
RVice
Beitrag von RVice »
Is there an easy way to get a report of how long someone was in a specific role?
The use case, we have a qualification for "life member" when they make 20 years of being a regular paid member. The years need not be sequential. Ideally, it would be recorded paid years, but that requires using a separate plugin or recording system of payments.
Ideally, I could just get a CSV export of the start/end years of roles for members or a rollup sum of those years. When we hit 19-20 years for instance, it should be a relatively short list to figure out if they actually qualify for year 20 or have to wait one more year.
I suppose with AI now, I could give it the admidio repo and ask it to create this report as well. Just seeing if there's already something there.
RVice
Re: Get a report of how many years someone is in a role
Beitrag von RVice »
FYI, I took a stab at it, but it modifies the existing category report at its core. Not sure that's the best thing to do, but it does solve what I need.
https://github.com/Admidio/admidio/pull/2042
Hi Rvice,
If you use groups and roles to select a list configuration in V5 with the following columns:
Last Name, First Name, Membership Duration, and a Role, admidio will display the desired data.
You can then export this data and process it further.
RVice
Beitrag von RVice »
@greno, it can be done, but requires exporting and doing excel/google sheets formulas. Additionally, our roster is a little more complicated in that there are multiple roles to consider a "member for X year" calculation (Life Member, Member, Honorary Member, Applicant, Corresponding Member, Active Duty Member) versus our "Life Member Qualified" calculation (Member, Active Duty Member).
The Pull Request I put up, has both total years as a member (with selected roles) and total years towards life membership (with selected roles, the threshold number of years to achieve life membership and how many years someone has towards life memberhsip). This makes it very easy for us to generate our Life Member plaques and also to setup an anniversary notice in our newsletter.
I just put the PR 2042 to ready for review.
cherybomb
Beitrag von cherybomb »
I ran into a similar situation with membership tracking. If your system stores role history, exporting the role start and end dates to CSV is usually enough to calculate total qualifying years, even when membership periods aren't consecutive. For a 20-year life member requirement, I'd focus on generating a list of members with 18–19 accumulated years first, which makes the final verification process much easier and avoids reviewing the entire membership database.
Lennox
Beitrag von Lennox »
What are the primary differences between the data provided in Admidio V5 and the custom solution in PR 2042?
Thank you!
