Captcha not working
silverches
Captcha not working
Beitrag von silverches »
Hello,
I'm running 3.2.10 but for some reason the catpcha's aren't working. This was also the case in previous versions.
Phpinfo says GD is enabled.
Re: Captcha not working
Hi silverches,
are there some informations within the log?
Without other informations it's very hard to get the reason for this error since you are the only one reporting this :(
Best regards
silverches
Hi Fasse,
Sorry for the late reply, had notifications disabled. The logs gives no information. If i press view image it just says: Failed to generate captcha image, content has already been output.
This is most likely due to misconfiguration or a PHP error was sent to the browser.
Did you modified any files?
Could you set $gDebug = true; in config.php and look in the logs again?
