Administration - Menü
Offe
Beitrag von Offe »
Beim Aufruf des neuen Punktes Menü im Bereich Administration erscheint folgende Fehlermeldung im Errorlog:
[Sun Feb 25 14:59:19 2018] [warn] [client IP-Adresse] mod_fcgid: stderr: [2018-02-25 14:59:19.132465] Admidio.ERROR: L10N: Could not found text-id! {"textId":""} {"file":"/var/www/adm_program/system/classes/Language.php","line":113,"class":"Language","function":"get"}, referer: https://localhost/adm_program/modules/menu/menu.php
[Sun Feb 25 14:59:19 2018] [warn] [client IP-Adresse] mod_fcgid: stderr: [2018-02-25 14:59:19.149425] Admidio.ERROR: L10N: Could not found text-id! {"textId":""} {"file":"/var/www/adm_program/system/classes/Language.php","line":113,"class":"Language","function":"get"}, referer: https://localhost/adm_program/modules/menu/menu.php
[Sun Feb 25 14:59:19 2018] [warn] [client IP-Adresse] mod_fcgid: stderr: [2018-02-25 14:59:19.167478] Admidio.ERROR: L10N: Could not found text-id! {"textId":""} {"file":"/var/www/adm_program/system/classes/Language.php","line":113,"class":"Language","function":"get"}, referer: https://localhost/adm_program/modules/menu/menu.php
Gruß Offe
Re: Administration - Menü
Offe
Beitrag von Offe »
Der Fehler tritt auch bei allen anderen Modulen auf:
[Sun Feb 25 18:00:47 2018] [warn] [client IP-Adresse] mod_fcgid: stderr: [2018-02-25 18:00:47.642000] Admidio.ERROR: L10N: Could not found text-id! {"textId":"Homepage"} {"file":"/var/www/adm_program/system/classes/Language.php","line":113,"class":"Language","function":"get"}, referer: https://localhost/adm_program/index.php
[Sun Feb 25 18:01:54 2018] [warn] [client IP-Adresse] mod_fcgid: stderr: [2018-02-25 18:01:54.907537] Admidio.ERROR: L10N: Could not found text-id! {"textId":"Homepage"} {"file":"/var/www/adm_program/system/classes/Language.php","line":113,"class":"Language","function":"get"}, referer: https://localhost/adm_program/modules/p ... rences.php
[Sun Feb 25 18:02:21 2018] [warn] [client IP-Adresse] mod_fcgid: stderr: [2018-02-25 18:02:21.337456] Admidio.ERROR: L10N: Could not found text-id! {"textId":"Homepage"} {"file":"/var/www/adm_program/system/classes/Language.php","line":113,"class":"Language","function":"get"}, referer: https://localhost/adm_program/modules/dates/dates.php
[Sun Feb 25 18:04:14 2018] [warn] [client IP-Adresse] mod_fcgid: stderr: [2018-02-25 18:04:14.076703] Admidio.ERROR: L10N: Could not found text-id! {"textId":"Homepage"} {"file":"/var/www/adm_program/system/classes/Language.php","line":113,"class":"Language","function":"get"}, referer: https://localhost/adm_program/modules/a ... ements.php
[Sun Feb 25 18:04:54 2018] [warn] [client IP-Adresse] mod_fcgid: stderr: [2018-02-25 18:04:54.339466] Admidio.ERROR: L10N: Could not found text-id! {"textId":"Homepage"} {"file":"/var/www/adm_program/system/classes/Language.php","line":113,"class":"Language","function":"get"}, referer: https://localhost/adm_program/modules/d ... nloads.php
[Sun Feb 25 18:05:10 2018] [warn] [client IP-Adresse] mod_fcgid: stderr: [2018-02-25 18:05:10.644447] Admidio.ERROR: L10N: Could not found text-id! {"textId":"Homepage"} {"file":"/var/www/adm_program/system/classes/Language.php","line":113,"class":"Language","function":"get"}, referer: https://localhost/adm_program/modules/m ... ssages.php
Gruß Offe
Ich schaue noch mal drüber.
Hmm, ich kann das nicht nachstellen. Er sucht bei dir nach Homepage, das ist wahrscheinlich ein Profilfeld bei dir oder? Aber auch in meiner Testumgebung arbeite ich bei Profilfeldern ohne Übersetzungsstring und ich bekomme diese Meldung nicht.
Offe
Beitrag von Offe »
Ich weiß woher der Eintrag kommt. Das ist ein neuer externer Menüpunkt, so wie ich ihn hier beschrieben habe: viewtopic.php?f=13&t=7758
Solltest du als in der Spielwiese unter dem Eintrag "Admidio Homepage" auch finden. Sobald der Menüeintrag gesetzt ist, dann kommt bei jedem Klick innerhalb von Admidio die Fehlermeldung im Errorlog.
Gruß Offe
Hallo Offe,
das Problem ist auch behoben. Allerdings dann erst in der Beta 3.
Offe
Beitrag von Offe »
Ich habe weiterhin die Fehlermeldungen im Logfile stehen (Beta 2 + aktueller Commit aus Github)
Gruß Offe
Offe
Beitrag von Offe »
HIer war auch der Fehlerteufel bei mir am Werk beim Übernehmen des Commits. Fehler ist gelöst
Gruß Offe
