when is the release date for 4.1
plawrie
Beitrag von plawrie »
Do you have a release date for the stable version of 4.1?
plawrie
Re: when is the release date for 4.1
I should have added to my question on the release date for 4.1
I have created extra profile fields and populated the database. If the 4.1 update is applied, does that reset the profile fields to default? Especially as the member data which has been added uses the additional fields.
We will release the 4.1 within the next week.
All your data will still be there after the update.
