File permissions to enable adding fields etc? (Solved)
davidoclubb
Beitrag von davidoclubb »
Hi all, I have just installed Admidio and it looks great for our little charity. However I'm unable to add fields, roles etc, and I suspect this might have to do with permissions in the file system. Is there a guide anywhere that specifies read/write access for user, group, world etc? Apologies in advance if I missed it in the documentation, and thankyou!
Zuletzt geändert von davidoclubb am 6. Jul 2022, 16:12, insgesamt 1-mal geändert.
davidoclubb
Re: File permissions to enable adding fields etc?
Solved my own problem. The 'create role' button is in the LHS menu, which is a bit different to how the documentation shows it.
Re: File permissions to enable adding fields etc? (Solved)
Hi ,
with the next version 4.2 We will move the button from the left Menu to the Top of the main page.
