After installation, unable to login with administrator credentials, "Your login data were correct but you are not an act
kylebialo
Beitrag von kylebialo »
After the initial installation of Admidio, I am unable to login to the organization that was created. When I attempt logging in with the credentials created during installation, I receive the error "Your login data were correct but you are not an active member of this organization."
I have made sure the credentials are correct, reinstalling the software, and re-creating the mysql database.
I can confirm there have been tables made in the database, so it appears the installation completed successfully.
Anyone have any ideas on how to correct this issue?
Re: After installation, unable to login with administrator credentials, "Your login data were correct but you are not an
Hmm that is strange. I tested it with 4.1.14 and I could login with the user I created during installation.
I found a bug that may be responsible for that behavior.
Please retry the installation with the new version 4.1.15 and give me feedback.
Yev
Beitrag von Yev »
I had installed version 4.1.16 and have the same problem
Please help :)
Hi Yev,
which database are you using ? PostgreSQL or MySQL?
Yev
Beitrag von Yev »
Hello :)
I use MySQL and now installed version .17, have the same problem
Hmm, I don't know the reason for this problem.
Could you please set the debug mode and than try to login. After that have a view in the adm_my_files/logs and search there for an SQL Statement that starts with
SELECT mem_usr_id
Could you please than post the complete statement here.
Yev
Beitrag von Yev »
I did it, but couldn't find. Please all file with log https://drive.google.com/file/d/1X9Wnz_ ... sp=sharing
Thank you!
Hi Yev,
within your logfile there are only the following errors:
- incorrect username/password
- Maximum number of invalid logins!
But there is not the described error of this thread.
Yev
Beitrag von Yev »
Hi Fasse,
Thank you so much. Have you any ideas, what can I do for a good work? I made installions three times and have all time the same problem.
Maybe there is admin configuration somewhere in files?
Best regards,
Yevheniia
zapra
Beitrag von zapra »
Sorry to spawn this old thread.
But, I also experienced this issue on the Admidion version 4.2.10.
When I create a new administrator member, in the table _users, column usr_valid is always set to FALSE.
I have tried to change it to TRUE. However, it's only for bypassing the login. After successfully logging in, the column usr_valid automatically back to FALSE.
So, how to permanently make the value of the usr_valid column TRUE for the administrator role?
Which database are you using?
zapra
Beitrag von zapra »
I am using PostgreSQL.
I get some information as insights as far as I tested.
First, the state of usr_valid changed to FALSE is triggered when you click and execute "send e-mail with username and password" from the Members page.
Second, the state of usr_valid changed to FALSE is triggered when you successfully logged in.
The condition above is valid for all roles.
Thanks for the notice.
I saw this problem before with PostgreSql. For some reason postgresql has problems with our boolean fields. I will have to Look at this again.
zapra
Beitrag von zapra »
fasse hat geschrieben: 27. Jul 2023, 13:52 Thanks for the notice.
Thank you for the information. I will consider using MySQL.
Is any specific MySQL version that's stable for Admidio?
