Disable the Capture?
proffalken
Beitrag von proffalken »
Whilst the capture is good for preventing spam/bad actors, it's a really poor user experience for those with screen readers etc.
Is there any way to disable the capture completely so our members that require greater accessibility are able to sign up without it?
Re: Disable the Capture?
Yes, you can go the the registration preferences and disable the captcha there.
