FormFiller plugin
isleofwight
FormFiller plugin
Beitrag von isleofwight »
I am struggling with the Formfiller plugin.
for the plugin formfiller I have gone to overview.php in templates and inserted the script:
<div class="admidio-overview-plugin col-sm-6 col-lg-4 col-xl-3" id="admidio-plugin-formfiller">
<div class="card admidio-card">
<div class="card-body">
{load_admidio_plugin plugin="formfiller" file="formfiller.php"}
</div>
Which is a copy of the same script for each of the plugins but with formfiller subtituted
When I run this on the web I get an error
"The authorization check of the plugin failed. There is more than one menu item with the same URL defined.
=> /admidio/adm_program/overview.php"
Any suggestions would be a big help as this is a key plugin for me
PHP for the formfiller is as follows ( but I am not clear on how to complete this line:
$scriptName = substr($_SERVER['SCRIPT_NAME'], strpos($_SERVER['SCRIPT_NAME'], FOLDER_PLUGINS));)
<?php
* FormFiller
* Version 3.1.0
* Dieses Plugin für Admidio ermoeglicht das Ausfuellen von PDF-Formularen sowie das Erstellen von Etiketten.
* Autor: rmb
* Hinweis: FormFiller verwendet die externen PHP-Klassen FPDF und FPDI
* Compatible with Admidio version 4.1
* @copyright 2004-2022 The Admidio Team
* @see https://www.admidio.org/
* @license https://www.gnu.org/licenses/gpl-2.0.html GNU General Public License v2.0 only
require_once(__DIR__ . '/../../adm_program/system/common.php');
require_once(__DIR__ . '/common_function.php');
require_once(__DIR__ . '/classes/configtable.php');
//$scriptName ist der Name wie er im Menue eingetragen werden muss, also ohne evtl. vorgelagerte Ordner wie z.B. /playground/adm_plugins/formfiller...
// only authorized user are allowed to start this module
if (!isUserAuthorized($scriptName))
$gMessage->show($gL10n->get('SYS_NO_RIGHTS'));
// Konfiguration einlesen
$pPreferences = new ConfigTablePFF();
if ($pPreferences->checkforupdate())
$pPreferences->init();
else
$pPreferences->read();
Re: FormFiller plugin
I think the english documentation of the plugin is not up to date. I will inform the plugin developer.
FormFiller cannot be integrated via overview.php. I just revised the English plugin page. Follow the instructions under "Installation" or "Update".
isleofwight
Thank you plus installed update to 3.2 and it looks as though it will work so far
