Form Filler: Deleted configuration, can it be restored
RVice
Beitrag von RVice »
I accidentally deleted a configuration, is there a place where I could restore this?
I had quite a few fields placed and would like to avoid doing this all over again.
RVice
Re: Form Filler: Deleted configuration, can it be restored
Beitrag von RVice »
Found a way looking at the logs, had to decipher the internal field names, but got it rebuilt quickly.
There is no direct route. to restore a configuration, but next time before you delete a configuration, you should save this configuration via export/import and create a cfg file. You could import the created cfg file again later if you need it again.
RVice
Beitrag von RVice »
Thanks for the suggestion
I saw that option after the fact :roll:
